Rear brake help on a 99
Old Sep 22, 2007 | 01:44 PM
1qckdodge's Avatar
I need to loosen the rear brakes on my truck as they are way to tight, and for the life of me I cant seem to get the rod to loosen, what am I supposed to push on? is it the other side of the rod? Thanks.
Old Sep 22, 2007 | 06:40 PM
infidel's Avatar
Look in the adjustment hole with a flashlight you'll see a flat metal piece directly under the starwheel. Push in on this with a screwdriver while turning the starwheel downward.
Old Sep 22, 2007 | 06:47 PM
Geico266's Avatar
Infidel has it right. The inspection hole you want to look in is the rear most, lowest one. This is true for both sides BTW.
Just don't panic. I have had them very tight before and thought I was screwed, just figure out which way to loosen it and go the other way after you press in the adjuster.
Old Sep 22, 2007 | 09:28 PM
1qckdodge's Avatar
Thanks guys, I got it, truck felt like I was towing a big loadat first I thought somethin was wrong, but then figured out what I had screwed up.
reaves11
Feb 10, 2013 02:29 PM
RichN
0
Aug 6, 2010 06:52 PM
johnls
Apr 1, 2009 01:51 PM
mudwisr2
Feb 22, 2008 11:51 AM
scuzman00
Mar 13, 2006 01:58 PM
