Vexing Tranny Issue, please help!
Old Sep 22, 2007 | 04:15 AM
Bfluri's Avatar
Exclamation Vexing Tranny Issue, please help!
First I would like to say that I have read every post I can find reguarding transmissions and issues likewise. Nothing I have come across has problems I am having.
I have an 04 3500 48RE. The tranny is slipping just slightly and at low speeds it sometimes hunts for gear. Checked the fluid and it was burt. Got a new clutch kit, new bands and Mag fluid pan. Installed all this stuff, adjusted bands, and added about 2000000 qts of fluid, until it was full. Took for a test drive and all was fine at first then it felt like someone was hitting the brakes all of a sudden. Pulled over and checked everything out and found nothing wrong. On the way back it drove normal until I got to my place where it started to hunt for gears again, at about 15MPH.... I dont know enough about A/T to figure this out.... My truck is a theft recovery, so there is no warenty......Please help!! I have to drive across the country next week!!
Old Sep 22, 2007 | 07:07 AM
brian55290's Avatar
did whoever built it change all the solenoids and how many miles on it. poss. tps, gov sensor or transducer
Old Sep 22, 2007 | 12:47 PM
Bfluri's Avatar
I rebuilt it but no I did not replace anything other then what I mentioned..
Old Sep 22, 2007 | 01:10 PM
rustyshakelford's Avatar
is it throwing any codes?
brett
Old Sep 22, 2007 | 01:23 PM
Bfluri's Avatar
Sometimes I get TC clutch circuit low......dont know if that could be due to my TC lockup switch thouhg. Thats the only code I get and its random at best
Old Sep 22, 2007 | 04:49 PM
Bfluri's Avatar
Figured it out! The T/V cable was getting stuck and didnt allow me to use the full throw of the pedal.....Good as new now!
Old Sep 22, 2007 | 05:15 PM
Dean Snow's Avatar
i had that same problem and messed with it for a while, thought my torque converter was going, i used a little grease and pulled the cable some and it worked like a charm after that, it has done it 2 more times after that but it just needed more grease, just carry something with you in case it sticks again!! good luck with it!
Old Sep 22, 2007 | 09:52 PM
Bfluri's Avatar
Mine wa slightly different, well the cause was. It bolies down to me being an idiot. There is a snap-ring that holds the lever arm in place and I didnt install it...oops. The whole rod was sliding down into the tranny cases and when it would move there was interfearance.
mtdoragary
Apr 8, 2013 08:58 PM
noizykrikit
Dec 23, 2011 05:41 PM
SuperiorRam
Mar 15, 2007 03:10 AM
CASMOKIN
Nov 7, 2006 08:05 AM
DDysput
May 5, 2004 07:44 AM
