Ran Truck out of Fuel on the highway
Old Nov 27, 2003 | 10:54 AM
hellotbone's Avatar
Our Bonehead salesman ran out of fuel on the highway with our 24 valve trucks its a 99 auto. My question is he said it started smoking like crazy when it was dying could he have done any engine damage or would it just smoke cause its running out of fuel. I also am aware that he could have hurt the VP running it out of fuel.
Old Nov 27, 2003 | 04:29 PM
jrs_dodge_diesel's Avatar
Re:Ran Truck out of Fuel on the highway
From what I have learned on this site, he could have damaged the lift pump and the VP44. I reccomend having the fuel pressure checked.
Another word of advice that I have heard on this site, treat the 1/4 tank mark like it is the empty mark on your guage.
Old Nov 27, 2003 | 09:48 PM
rich's Avatar
the two times i've run out of fuel it didnt smoke. it also didnt seem to hurt anything either.
Old Nov 30, 2003 | 11:25 AM
Redleg's Avatar
Could he have run out, got rescued with a couple gallons of gas, then saw smoke?
Old Nov 30, 2003 | 12:58 PM
marksmith's Avatar
Rescued with gas? That might cause a few problems. IMHO you should fill er up and check FP then go from there. It isn't good by any means to run out of fuel but they should survive it.
Mark
Old Nov 30, 2003 | 02:00 PM
Redleg's Avatar
Just wondering if he "conveniently" forgot when he actually noticed the smoke coming out, if he did attempt the wrong fuel.
Old Nov 30, 2003 | 04:52 PM
MnTom's Avatar
NAW Redleg- a salesman would never "conveniently" forget that!!!!!!
Old Dec 1, 2003 | 06:48 PM
MCummings's Avatar
Smoke wouldn't be too uncommon, especially if when the truck starting running out of fuel, he started giving it more pedal. Fill 'er up, bleed the system, fire the truck up, and you should be fine. The VP's aren't THAT fragile, although, if it was getting to be on it's last leg,, it coulda :-* ya goodbye.
Merrick
Old Dec 3, 2003 | 03:51 PM
just_crankin_it's Avatar
That’s how I found out my fuel sending unit was crap. Cruising at about 75-80 MPH al of a sudden a huge WHITE puff of smoke, a little knocking and DEAD. Barely made it to the shoulder. Filled ‘er up bled the system and it fired right up. Since then just like jrs_dodge_diesel said, I treat ¼ tank as empty.
Deadbunny
Mar 29, 2009 10:17 PM
Buckshotmckee
Jun 10, 2005 12:23 PM
Dodgezilla
25
Jan 29, 2004 02:21 AM
shawndennis2
Mar 30, 2003 10:06 AM
