Ran it of fuel
Old Jun 15, 2005 | 09:57 AM
CASMOKIN's Avatar
Ran it of fuel
Yes its true I ran it out of fuel. Unfortunatley my fuel gauge lied to me. This happened last week. I put some more fuel in it, primed the heck out of it and finally after a few hours got it started. The next day I took a long trip and I noticed it wasnt running that good, less power, higher than normal exhaust temps but my fuel pressure was fine. I let my wife drive it yesterday to the store and it died on her half way there. I tried to get it started this morn. w/ no luck. I'm almost certain the lift pump is gone, how do I check to see if injection pump is cooked as well. Also if I was having fuel issues why wasnt there any variation in my fuel pressure?
Old Jun 15, 2005 | 10:04 AM
RustyJC's Avatar
From the off position, turn the ignition switch to on, then off, then on, then off, then on and watch the odometer window for DTCs (diagnostic trouble codes) that pop up as it goes through its cycle test. Hopefully you won't see the dreaded P0216 (injection pump timing error) that spells the end of your VP44 injection pump. Let us know what you find.
Rusty
Old Jun 15, 2005 | 12:22 PM
CASMOKIN's Avatar
Thanks Rusty I'll check it out
Old Jun 15, 2005 | 09:34 PM
Stamey's Avatar
Your sig says you have a FP gauge. You would know if you have a fuel pressure problem. If there is an injector pump problem you will start getting codes, like the infamous 216 code.
Chris
Old Jun 17, 2005 | 01:50 PM
CASMOKIN's Avatar
Yes I do have a FP gauge. The wierd thing is that shortly before this happened I noticed that my FP was running hire than normal, as well as my exhaust. I was thinking that my FP would of registered below the average. I checked for the 216 code-nothing.
Old Jun 17, 2005 | 02:00 PM
RustyJC's Avatar
Nothing, as in no codes at all?? Did you see Pdone pop up at the end of the check?
Rusty
Old Jun 17, 2005 | 02:55 PM
CASMOKIN's Avatar
Maybe, Im not looking in the right place. This is my first time checking for something like this. I turned the ignition on and off quite a few times and nothing, am I doing something wrong?
Old Jun 17, 2005 | 03:00 PM
RustyJC's Avatar
To do the diagnostic, the ignition has to be turned on exactly 3 times as I outlined above. Anything more or less won't work. The third time it's turned on, leave it on and watch the odometer (mileage) window. You should see the truck go through a diagnostic routine. When it is finished, even if no codes are present, it should show Pdone (PCM check completed) in the odometer window.
Rusty
Old Jun 17, 2005 | 03:02 PM
P.J's Avatar
P.J
Leave it in the "on" position (not started). Unfortunately my guess would be the injection pump. Mine crapped out a few weeks ago. Good Luck. How many miles?
DR3500's Avatar
off to on w/o starting truck, do this 3 times and leave the key on at the end. watch the odometer window for codes. at the end if you did it right it will show Pdone in the odometer window.
Old Jun 17, 2005 | 03:07 PM
CASMOKIN's Avatar
OK guys, got it to work, thanks for holdin my hand . I did it and got pdone, no codes. Truck has 74,000 miles.
jefe4x4
25
Dec 15, 2011 07:33 AM
Buckshotmckee
Jun 10, 2005 12:23 PM
Marine
Sep 15, 2003 11:54 PM
shawndennis2
Mar 30, 2003 10:06 AM
