Ran out of fuel
Ran out of fuel
First thought it was the Injection pump. Stopped dead in its tracks. Then thought it was the lift pump, but it was making noise, so I thought it was good. Took out the fuel filter, saw that no fuel was being pumped into the canister so I changed the fuel filter since I had it out already. Then I thought the lift pump was dead. Turns out I was out of fuel (figured it out after a couple of hours). Filled it up and it still would not start. I cycled the lift pump 15-20 times to no avail. Then I cracked cyl 1 and 3 and cranked it until all foam was out of the lines. put it back together and it started up. Now I guess I have a problem with the sender in the fuel tank because it said I had 3/8 of a tank left. It was bone dry. My tank is 36 gal and I put in 35.97 gallons.
Mike
Mike
Re:Ran out of fuel
Same thing happened to me right in the middle of a busy intersection. What a pita. Seems the sending unit is a relatively common failure. The sending unit itself is not that bad but again a pita you have to drop the tank or raise the bed. Consensus seems to be raise the bed enough to get to it.
Re:Ran out of fuel
With all of the lift/injector pump failure stories, we forgive you for checking last the thing you would have normally checked first.
I'd bet that running out of fuel here still beats having a full tank "over there"
Re:Ran out of fuel
It was a good lesson- not to rely on what the gauge says. I should have gone underneath and tapped on the tank. You bet- I'd rather be here than there.
BigK- Did you get my PM about the scotty?
Mike
Mike
Re:Ran out of fuel
I have run mine out twice both times I still had some diesel left but, it was low and I took a corner to fast. I think it slushes to one side and I suck air. Hard lesson learned twice now :
jefe4x4
25
Dec 15, 2011 07:33 AM
Deadbunny
Mar 29, 2009 10:17 PM
Buckshotmckee
Jun 10, 2005 12:23 PM
