radiator fan sheered off
Old Jun 27, 2007 | 01:08 AM
bootsdodgejn's Avatar
Unhappy radiator fan sheered off
hey yall my fan sheered off when i was parking last nite and want to so if it is easier to send it to the shop or do it myself with minamal tools please help
Old Jun 27, 2007 | 07:01 AM
Stamey's Avatar
So you replacing the radiator too? You can probably get the nut off of the idler pulley quite easily now, since that pesky fan is out of the way. Usually this requires a special tool. It's pretty much take the old fan clutch nut off and put the new one on, swapping the actual fan blade ot the new clutch, if it is still usable, otherwise you bought a new fan blade too.
Chris
Old Jun 27, 2007 | 07:18 AM
donhov's Avatar
Have you had anyone including yourself work in that area recently? My friendly local dealer replaced my CP-3 on my 04.5 and didn't torque the bolts properly and did not use lock tite on them, resulting in fan coming off, destroying shroud, fan, fan clutch and some wiring, about $1600 worth of repairs. Dealer paid for all but took some persuasion from district manager. So if you had work done you might want to persue that avenue to save some bucks. Hopefully you didn't have a lot of damage.
Old Jun 27, 2007 | 09:16 AM
the dealer ship tooke out my radiator to flush it but i dont know if they touched the fan for that. is it normal for the fan to sheer off like that..
Old Jun 27, 2007 | 09:43 AM
dodgezilla04's Avatar
no it is not normal. did the bolts come out, or snap?
Old Jun 27, 2007 | 10:43 AM
donhov's Avatar
Sounds to me like someone at the dealership didn't follow all steps. I would return the truck to the place that did the radiator and have them fix it "Under Warranty" as it sounds like they made a mistake.
As far as any radiator damage probably not as the torque of the motor stopping reverses the fan rapidly and just snaps it off and throws it directly to the side and damage is done to the shroud and misc parts but not normally the radiator.
Good Luck....
Old Jun 27, 2007 | 10:55 AM
infidel's Avatar
I've seen blades shear off when someone puts cardboard in front of the radiator for the winter and doesn't cover it 100% or with a hole in the middle.
What happens is every time a blade passes though the airstream it flexes till it breaks.
ctd4stan
Feb 25, 2014 12:29 AM
8liter
Sep 22, 2012 10:19 AM
big jimmy
Jul 7, 2006 01:33 PM
Kass
Aug 31, 2005 05:37 AM
ruben
Oct 1, 2003 09:38 PM
