quick question - fuel filter up/down
Old Jun 24, 2006 | 12:34 PM
lglamb's Avatar
in middle of swapping lift pump (so far, kinda so good)
1. fuel filter canister has a disk piece in the bottom of it.
cleaned it some, still kinda cruddy. guessing leave it
in, but wanted to check.
2. Also, new fleetguard filter is flat on one end but has
a raised area around the center of the other end.
so, which end is up? (filter coming out flat on both
ends)
Thanks. Already regretting not having time to put
in frame-mount kit.
Lowell
Old Jun 24, 2006 | 01:05 PM
phox_mulder's Avatar
Filter can only go in one way, unless you got the wrong one.
The end with the hole has to go over the center post.
phox
Old Jun 25, 2006 | 11:42 PM
lglamb's Avatar
Oh. It only has a hole in one end.
Got thrown a bit cause the one I took out had holes on
both ends. Turns out the filter media had come disconnected
from it's endcap, which I didn't figure out until the new filter
wouldn't fit into the filter lid.
New lift pump in, not as much dead pedal. But still some, dangit.
Thanks,
Lowell
Clane
Dec 9, 2009 07:53 AM
sakisaki400
20
Sep 6, 2007 03:47 PM
Big Horn 06
Aug 26, 2007 02:23 PM
TxDiesel007
Apr 1, 2006 09:23 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
