driving home and lost clutch pedal
Old Jun 24, 2006 | 07:14 PM
davecregar's Avatar
I have a 03 HO diesel 6 speed 3500, when you push in the clutch pedal it feel like you have pressure then I just hear air comming from the clutch master cyl.?? help and ideals, and do you think this is covered under warranty?
thanks!! has 38,000 on it
Old Jun 24, 2006 | 09:23 PM
Stamey's Avatar
You may have popped a seal in the slave cylinder, and the brake fluid leaked out. Adding brake juice might get you to the dealer. Fill it up again and try it. Bleeding it consists of using the clutch pedal, as it is "self-bleeding".
This should be covered under warranty.
Chris
Old Jun 25, 2006 | 07:34 PM
davecregar's Avatar
clutch master cylinder
I took the master cyl off, and the seal on the very end had a tear in it, this is there the seal off the resivore when you are pushing the clutch pedal down, it pushes fluid to the slave cylinder and seals off the resivore, it was bleeding back into the res. instead of waiting on the dealer to get it in next week, I just ordered a new master cyl for it, $50.54, not bad but man the whole thing is made of plastic, this just aint like my IH pickup.
Old Jun 26, 2006 | 12:03 AM
scuzman00's Avatar
Hopefully you got it bled out by now. I had the same ordeal on my 02 and finally gave up and went to DC to get the slave/master assy with interconnecting lines. No blleding, quick install and no hair loss trying to figure it out. Hope ya got lots of pedal!!!!
Gary
Matt06
Aug 23, 2013 08:30 AM
CapnRam
Apr 4, 2009 09:41 PM
CapnRam
Apr 2, 2009 09:16 PM
jmccart
48
Jul 23, 2008 12:34 AM
WACTD
Jul 25, 2006 11:41 AM
