Quadzilla problems
Old Oct 13, 2005 | 04:19 PM
05dodgezilla's Avatar
Thumbs down Quadzilla problems
Well here it is i came upon a Duramin today i could see he had an edge box/attuide on the dash so im thinking with all the mods in my sig that i was gonna smoke this joker right !
So here we go i turn my box up to 140 hp setting and i lay'd into it. The egt's soared well above 1250 and rising. Next thing i know in the corner of my eye the CHECK ENGINE LIGHT IS ON! So i had to let him make me look like an idiot, man i could have done without that today, haven't got the code checked yet but i'll say its a fuel pressure code i'm calling quadzilla today! anyone else have this problem? Is it something i'm doing is my truck broke?
Old Oct 13, 2005 | 07:48 PM
jaymo's Avatar
I could be wrong but if you hit 1250 post turbo than that is really hot.
Old Oct 13, 2005 | 08:43 PM
rich's Avatar
Double check your plug connections, also the box will suck your fuel press to zero on a stock pump it does it to mine when i romp on it. Mine thru some codes and the plug connection was not connected all the way
Old Oct 13, 2005 | 08:47 PM
MadDog01's Avatar
As you can see I don't have the same set up. When you find the code let us know. You don't want to hold those temps for very long. I wonder what the duramx's exhaust temps were?
Gary
Old Oct 14, 2005 | 07:41 PM
Going tomorrow to get the codes i will post them
Old Oct 14, 2005 | 07:54 PM
kelley15's Avatar
Cant you get the codes doing the key switch trick with an 05? Turn the key from off to on 3 times without starting and codes should come up.
Old Oct 16, 2005 | 02:50 PM
huh i didn't know that but next time i'll try that !! Learn something everyday
Anyway took off quad and took to the dealer and code was just as i suspected high fuel rail pressure
mopar440cu
Nov 21, 2015 08:39 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
wdbates
Nov 9, 2005 11:10 PM
