problems with new Quadzilla box
Got a problem with my Quadzilla xzt box.
I had problems with the Box at first (missing on slight inclines at interstate speeds) and Quadzilla fix the problem. I now have a new problem with 7k miles of use my truck is now setting map sensor codes (out of parameters). I removed the box and installed by-pass keeping the harness in place and my codes cleared. I reinstalled the box and Map sensor code set in less than 300 miles of driveing. I wrote Quadzilla with problems but so far have been ignored for a week now. Anyone else having problems with the box setting codes?
only thing I would suggest is cleaning the connectors real good, I had some things happen that I can only blame on dirty connections, I cleaned mine with wd40 and then some electrical parts cleaner and have been problem free since. I never checked codes but the problem I had was much more scary,
WD Call Quad and explain the problem.
I'd personally check the connections and apply dielectric grease to them (similar to spark plug wire grease).
I have not heard of any problems with that box but...........
I have a quad race box and I've never had any problems with it nor Quads customer service.
Rick
Rick
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
04ctd
Oct 5, 2006 08:27 PM
Batts
35
Apr 12, 2006 04:19 PM
