Pump Jump!
Old Oct 2, 2004 | 11:56 AM
mhuppertz's Avatar
Pump Jump!
For a couple of years my truck had the habit of shutting down while I was driving, or not starting. I put a jumper wire from the fuel cutoff soleniod and with the key off would have to spark it several times before I could get the proper "click", and then it would start just fine.
Question, is this typical of the soleniod getting weak or dirty, of could it be periodic low voltage coming out of the SMEC?
The pump is now dead, so I'm hoping the problem will be solved with the new unit.
Ideas??????
Mark
Old Oct 2, 2004 | 12:01 PM
A lot of people have had problems with the connection at the terminals on the pump. The solenoid gets power from the ignition switch, not the PCM.
It does sound like your problem was with the solenoid since it took a few tries to make it move.
mullishacrew
Jul 21, 2007 09:03 PM
cby52
Dec 30, 2003 09:30 AM
Mexstan
Mar 3, 2003 07:35 AM
robsobx
Jan 3, 2003 04:10 PM
