Problem........
Old Oct 7, 2008 | 11:43 PM
TriSum's Avatar
Problem........
Here's the scenario...
2005, automatic, pulling ~20K up the Grapevine in California.
55ish mph, 200' water temps, 1300ish EGT, 35ish lbs of boost.
Truck has a BD downloader on tow and a juice w/ att on #2, intake and exhaust.
OK, going fine notice the boost is a little higher than normal and all of a sudden...........BOOM !! Hard miss, a loss of power and a vibration.
I put the flashers on and pull over. Truck is running, but missing badly. Shut it down and check codes, P3206 and a 33?>. Not sure what the last thing was but that is what it showed. Checked intercooler boots, all is well. I cleared the codes and started it up. Misses at idle but cleans up above 1500 rpm but has a hard miss/knock.
It seems to run fine, EGT's are good, no fuel in oil, boost is good, has a knock. Power is down, but I also turned the Edge off so that may be the power bit.
Everything seems fine made the trip all the way to Reno, NV, (had to make my delivery). Now I'm not sure what to do with driving it home to take my mods off or take it to Carson Dodge.
Any input ????????
Thanks,
David
Old Oct 8, 2008 | 12:02 AM
98whitelightnin's Avatar
If its still under warranty I would try to get it home and take all of your after market extras off then take it to the dealer and play dumb!
Old Oct 8, 2008 | 12:35 AM
mpracehemi's Avatar
If I were you, check out the dealerships in your area that have new lifted trucks, that usually means that they are a factory authorized to 'modify'. I would leave your mods on 'cuz they're gonna know after they plug in their dionostics. They're going to see the previous codes that where cleared, I think. There is always some telltale sign that you had something.
Plus, almost (not everyone) everyone adds a programmer to try and get better fuel millage. That's what you can say.
Old Oct 8, 2008 | 12:38 AM
BigIron70's Avatar
Cummins Guru
I would have it checked out first. Might just save your engine from serious damage. Just could be injector gone bad. A scan is all it would take to find out what injector is bad. Could be on your way home in one hour and $600 poorer.
Old Oct 8, 2008 | 08:33 AM
GAmes's Avatar
There is no point in removing the box, they would know you had one, plus deception is fraud. Carson Dodge has a very good rep, I'd take it there.
Old Oct 8, 2008 | 04:19 PM
TriSum's Avatar
It now sits in the hands of Dodge. We'll see what happens. I will keep you guys updated.
David
Old Oct 9, 2008 | 03:54 PM
TriSum's Avatar
Dun......dun...dun..duunnnn !!!!!!!!
Well just got word from Dodge.
SHORTBLOCK !!!
Something let go inside. From the initial exam they found 2 bad injectors and something wrong inside the engine. They will pull it apart and check everything else out.
Anyone want to give me a ride home.....
David
Old Oct 9, 2008 | 05:36 PM
06 DIESEL's Avatar
Is it going to be covered under warranty?
Old Oct 9, 2008 | 05:58 PM
TriSum's Avatar
YES !!! It is. 5/100,000
The guys have been great at the dealership. They said the injectors sticking must have caused the problem.
David
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
