Power Steering Pump Problems
When the temp started to drop I noticed that when i started my truck the power steering pump would whine
, when I turned the wheel or stepped on the brake pedal. But it would go away when everything warmed up.
Now It whines all the time, I checked the dip stick and the oil was really foamy. Do any of you guys have any suggestions. I need HELP.
Either way will work. When I use a pump to suck out the contents of the reservoir, I will do it 3 or 4 times. Empty the reservoir and refill, drive the truck for a day, then repeat. It really is amazing what fresh synthetic PS fluid will do!
The manual says not to use ATF. I flushed it this morn, and put fresh stuff in, what came out of that pump looked like a foamy oil/water mix that was dark brown. I also cut some off the return hose end and looped it behind the supply hose so it won't be higher than the resivior. Mechanic at dodge said to do it, and it shouldnt be a problem again.
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
amartinson
0
May 4, 2003 01:55 PM
No wonder it was making noise!
