Power Steering Pump
Old Oct 17, 2003 | 11:06 PM
DODGE4X4's Avatar
Power Steering Pump
My lid on my pump leaks fluid out bad :- . I was wondering if any of yall has had this problem and if the repair is as simple as a new lid ???
Old Oct 17, 2003 | 11:40 PM
RCW's Avatar
RCW
Re:Power Steering Pump
There should be no leakage from the cap unless the pump was filled to the hot line when it was cold, or the cap is defective.
If the fluid is foamy when you pull the cap, you need to check for air leaks in the inlet hose.
Old Oct 18, 2003 | 10:25 AM
DODGE4X4's Avatar
No it isn't overfilled but, I will look for the air leak maybe that is my problem.
tony99
Apr 9, 2014 08:25 AM
DodgeCowboy
Aug 28, 2006 08:57 PM
powerwagon440
May 25, 2003 02:31 PM
amartinson
0
May 4, 2003 01:55 PM
