Please Help, Headlights
Old Nov 23, 2009 | 12:40 PM
pogo1's Avatar
Hey,
I got in my truck last night and the headlights wouldn't come on. The fog lights DO come on. Is this probably a fuse? I looked in the fuse box in the cab and cant find a fuse marked headlights. Where is the fuse located exactly?
Hope you guys can help me out.
Thanks
Old Nov 23, 2009 | 01:19 PM
cmac's Avatar
what year truck is it? i'll run out and check my 98 and edit my post. i had the same problem in my 96. turned out to be the actual headlight switch. i think it was like $16 to replace from Auto Zone.
EDIT: Ok, i checked the 98 in my sig. and i could not find a fuse inside the truck for headlights. i found it in the fuse block under the hood, on the drivers side fender. its a little black box behind the battery. if you pull the cover off there should be a label with "head lamp" on there. for mine it was a 40a on the left side 5th space down. hope this helps
Journier
21
Nov 26, 2010 08:41 PM
DHT
Apr 2, 2010 07:12 AM
Common
15
Jun 15, 2007 12:13 PM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
