truck wants to jump
Old Oct 3, 2009 | 12:01 AM
silotree's Avatar
truck wants to jump
i just bought a 2001 dodge cummins 295,750 miles. my first diesel. i have noticed that everytime i take off and i am turning my rear-end wants to jump its not real bad just didnt know if it is anything to worry about.
Old Oct 3, 2009 | 09:03 AM
Busboy's Avatar
If it's in 4 wheel drive it would want to hop in a turn but it could be the front or the back hopping. If in 2 wheel drive in a turn and the truck has a limited slip dif and there is not the correct amount of friction modifier added to the rear axle oil then it would feel like it's hopping.
If you get under the truck in neutral and try to shake the drive shafts to see if there is play in the universal joints or hangar bearing. Also the rear pinion going into the axle and the output at the transmission or transfer case if 4X4.
rich's Avatar
change the fluid. sometimes when the fluid is old it will cause the semi posi to start locking up when turning
Old Oct 3, 2009 | 12:32 PM
silotree's Avatar
thank you for your help
Old Oct 3, 2009 | 05:32 PM
RPegram's Avatar
Could someone have put a locker in there? They will hop on turning when giving it a little go pedal. Been there and don't really care for them in a truck driven on the road very much.
Old Oct 4, 2009 | 12:57 AM
silotree's Avatar
it only dose it if im taking off from like a stop sign or stop light when i turn either direction
2001 dodge cummins stock
Old Oct 4, 2009 | 06:57 AM
JP-4.5's Avatar
Drain the rear end and see what it looks like. Replace fluid and friction modifier and see if it helps.. With those miles and just being purchased who knows when it may have last been serviced. If it was me all of the fluids would be changed so you could start a regular maintenance schedule.
It would help to know more about the truck? Automatic? Standard? Any modifications? Fill out your signature so that others can help diagnose.
Old Oct 4, 2009 | 09:00 PM
silotree's Avatar
its a 2001 cummins auto, nothin done to it bone stock
Old Oct 4, 2009 | 09:15 PM
DiezelSmoke's Avatar
Sounds normal if it is limited slip, there is a TSB about it.
Old Nov 24, 2009 | 12:08 PM
DAK62's Avatar
mine did that adn i pulled the cover to see that the rear end was blown but it still drove on like 4 teeth
Mexstan
Mar 3, 2003 07:35 AM
robsobx
Jan 3, 2003 04:10 PM
