pinion trouble
Old Oct 1, 2006 | 11:06 PM
cginwyo's Avatar
pinion trouble
Pinion seal went out on me last week, changed it out and changed the fluid. Now my pinion is getting hot. I probably lost a fair bit of fluid when it went out the first time but it wasnt totally dry may less that 1/2. I know the fluid loss isnt good for it. But could i have overtightened the pinion nut and therefore now i have a heating problem. I pulled the cover and everything looks good and the pinion bearing also look ok and has no slop. These are shimmed correct?
Old Oct 1, 2006 | 11:45 PM
53 willys's Avatar
I'm a little confused. After the seal change you added more fluid right??
Old Oct 2, 2006 | 12:08 AM
XLR8R's Avatar
You changed the pinion seal out yourself, or had it done?
Old Oct 2, 2006 | 12:10 AM
cginwyo's Avatar
I changed the seal myself, and I did change the fluid and added the limited slip stuff
Old Oct 2, 2006 | 12:14 AM
XLR8R's Avatar
Well, when you torque the pinion nut the crush sleeve (you used a new crush sleeve, right?)
Did you put the shims for the posi back in the same place?
Old Oct 2, 2006 | 12:18 AM
53 willys's Avatar
I would think the dually is this spec instead????
this is the 286 RBI AXLES
Old Oct 2, 2006 | 12:21 AM
cginwyo's Avatar
Ok now you have me confused, everything I have read says these are shimmed and dont have a crush sleeve, as far as the shims for the posi, i never touched them. All I did was change the pinion seal, put everything together again, filled it up and now my pinion is getting hot.
Old Oct 2, 2006 | 12:23 AM
cginwyo's Avatar
I have the dana 80 dually
Old Oct 2, 2006 | 12:24 AM
53 willys's Avatar
Old Oct 2, 2006 | 12:30 AM
cginwyo's Avatar
215-330 ft lbs. on the pinion nut. Then I probably had it too tight. Now does this actually have a crush sleeve or is it shimmed? I cant see a crush sleeve in it and what little driving i have done i dont think that i have hurt the bearings. I cant move the shaft up/down or left/right, and there are no metal shavings in the oil or on the magnet.
Old Oct 2, 2006 | 12:31 AM
53 willys's Avatar
weird I cant find anything about the dana 80 for that year??? I sure that's whats In there right??
Old Oct 2, 2006 | 12:34 AM
53 willys's Avatar
think it's this spec
Old Oct 2, 2006 | 12:35 AM
cginwyo's Avatar
when i bought the seal from the dealership( no one else stocks it) that is what they called it. They looked it up from my vin
Old Oct 2, 2006 | 12:36 AM
53 willys's Avatar
Sorry I'm not much help
Old Oct 2, 2006 | 12:38 AM
cginwyo's Avatar
thats what i went off of when i tightened it the first time, the 500 ft lbs.
