P code Help
Old Sep 16, 2005 | 09:40 PM
cville6's Avatar
P code Help
This has happened a couple of times now. Driving along at surface street speeds (25-35 MPH) and the engine "stumbles" a little but quickly returns to normal operation and the check engine light comes on. Had the code checked and P0121 was the only code. Anyone have experience with P0121?
Old Sep 16, 2005 | 10:30 PM
J BODY's Avatar
Accelerator Pedal Position $en$or issue.
Old Sep 17, 2005 | 12:43 PM
phox_mulder's Avatar
You can try resetting it and see if it helps.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Usually it bandaids the problem for a little while, lets you save up for a new APPS.
phox
Old Sep 17, 2005 | 09:19 PM
cville6's Avatar
Exactly where do I find this APPS? I was told by some one that the trucks with manual transmissions did not have an APPS. Is this true?????
Old Sep 18, 2005 | 05:05 PM
It is mounted to the engine, up near the injection pump.
Yes, all 24 valve trucks have an APPS.
There is no direct connection between the go pedal and the engine, it is "fly by wire", all electronic.
phox
Old Sep 20, 2005 | 11:55 AM
dhughes's Avatar
This is sort of related, just thought you'd like to know for future reference:
http://www.i-hacked.com/content/view/95/45/
Maybe I'll make a seperate post of the i-hacked.com link too.
Old Oct 3, 2005 | 11:45 PM
Ramin's Avatar
I'm getting a P0016 What does thet mean?
Old Oct 4, 2005 | 08:20 AM
CTD NUT's Avatar
As near as I can tell, all OBD II DTC's start at 0100....are you sure the 0016 is correct?
Old Oct 4, 2005 | 04:15 PM
jrs_dodge_diesel's Avatar
Uh, oh. I hope it isn't P0216 (Injection pump timing control failure)
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
