p 1689
Old Sep 20, 2004 | 02:17 PM
rwstone1969's Avatar
p 1689
new member here, I'm having a fuel problem with my 2000 24 valve 2500 4x4 ( no mods). It seems like the lift pump is shutting off as soon as it starts. I've bleed the system several times, but no help. It is only doing this in the morning, in the afternoon when I bleed the system it works fine until the next morning.I did get a code of p1689 (no communication between ECM and injection pump module). I don't kwow where either of these components are located. Replaced lift pump no change.Thanks for any help I may receive.
Old Sep 20, 2004 | 09:43 PM
J BODY's Avatar
The diag for that code calls for testing continuity on various circuits. If all that checks out it's calling for replacing the ecm.
Old Sep 21, 2004 | 05:48 AM
thanks for the help!
Old Sep 29, 2004 | 08:44 PM
Zeddy's Avatar
When I got the 1689 code, I also had a p1688, all of this added up to a blown injector pump.
Hope that's not the case w/you but it was with me.
Good luck
Old Jan 24, 2005 | 12:22 PM
jjsj38's Avatar
Check the fuel pump relay under the hood. This will cause that code. I know, i simulated that fault with the relay and that code comes up.
Big Deezul
Sep 9, 2005 01:22 PM
jt_gladstone
Aug 9, 2005 11:24 AM
duallydave
Aug 7, 2005 05:34 PM
Shawnntx
Aug 4, 2005 10:42 PM
high country
Mar 7, 2005 12:37 PM
