oil pressure ?
Old Jun 10, 2007 | 11:21 PM
labreck's Avatar
Exclamation oil pressure ?
I notice my oil pressure drops to about 25psi at idle a week ago, it was time to change the oil so I dident think much of it. I changed the oil today and its still at 25psi at idle. Befor it would hold stedy at 40psi now it dosent. what changed.
The oil that came out looked ok about 3500 miles from the last change. I use Delo 15-40 and Fleetguard filters and changed the oil about every 3000 miles.
Old Jun 11, 2007 | 12:27 AM
johnh's Avatar
put a manual guage on it ..... i think you have a 1/8th pipe plug on top of your oil filter housing to test pressure. you might be surprised
Old Jun 11, 2007 | 12:44 AM
labreck's Avatar
Thanks, I'll try that. any body else?
Old Jun 11, 2007 | 08:02 AM
TonyB's Avatar
The factory gauge will show 40psi at idle after a long hot run (hill, load, etc); my real gauge shows ~10-12 psi at idle.
THe factory gauge is heavily damped and driven by the computer!
Install a real gauge & quit guessing!
HTH
Tony
Old Jun 11, 2007 | 08:30 PM
labreck's Avatar
the input is great. Though what Im wondering is what changed? Is the gauge just doing its factory (wired) thing. Im not too conserned, but the change is makes me think a little and was wondering your thoughts. thanks
Old Jun 11, 2007 | 09:41 PM
coachgrowl's Avatar
I tend to agree it is the change that is worrying. I have the factory gauge it starts out at around 45 when cold then drops to around 38 when warm at idle. goes back to 40 under load.
Old Jun 11, 2007 | 10:06 PM
labreck's Avatar
The change that Im talking about is that 2 weeks ago it stayed stedy at 40psi all the time. within 5 day it decresed to 25 psi at idle when warmed up, 40 psi running and 40psi cold. So in a week when warm it decresed 15 psi.
Old Jun 12, 2007 | 03:40 PM
Sea:\>Drive's Avatar
You are using the gauge exactly as gauges are designed and it warning of you of something due to the change. I still concur, confirm with a manual gauge - most typical problem is the sender is going bad, but they aren't too cheap.
Old Jun 12, 2007 | 08:45 PM
labreck's Avatar
I was afraid of the sending unit. I'll check it with a manual gauge. Thanks guys.
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
