Oil leak
Old Jul 5, 2004 | 09:40 PM
More Power's Avatar
Oil leak
Oil is coming out from around number1 exhaustmanifold port. Does not smoke at an idle does not noticible use oil and has no blow by engine has 53000 miles. Any suggestions.
Old Jul 5, 2004 | 10:26 PM
Smkndzl's Avatar
most times that would be called slobber and due to high idle times
Old Jul 5, 2004 | 10:33 PM
Sidewinder's Avatar
It may be diesel fuel and not oil. My truck was doing it and the cure was to remove the injectors and replace the copper washers/gaskets on the tips of the injectors.
Old Jul 6, 2004 | 10:23 PM
bmoeller's Avatar
Given low miles, it is doubtful, but it could also be valve stem seals.
Old Jul 26, 2004 | 02:31 PM
More Power's Avatar
I have checked copper washers and they are good and this truck does not idle muck at all is this a possible sign of a blown head gasket?
Old Aug 4, 2004 | 06:54 PM
More Power's Avatar
Just fixed my problem and it was valve stem seals what a relief thanks for all the suggestions.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
