quicky!!
Old Aug 1, 2004 | 09:50 PM
doodah's Avatar
quicky!!
just wondering about replacing bearings in the front axle? have a vibration when turning from a intersection and here a squeeking sound. how much am I looking at for price? easy or hard to do my self? and what about front axle u-joints? hard easy or what any help? would like to do my self have experience doing this just, not on this truck!thanx!
Old Aug 4, 2004 | 07:30 AM
Mcmopar's Avatar
Hi,
I just did a complete rebuild on my Dana 60, it is a pretty big job, you should have a puller for the front hubs, and a press to R&R the axle u-joints, all told I spent about $1,500.00. The u-joints are about 35.00 each, my 98.5 with 4 wheel ABS has the super expensive front hubs, 483 for one side 683 for the other from the dealer!! NAPA can get them for abour 380 each. Make sure you replace both seals, you will need to remove the ring gear to replace the driverside seal. The passenger side seal can be installed through the central axle disconnect opening, not an easy task but there is enough room the get the seal in.
Good luck,
It took me a day and a half, but I also did rotors and the ball joints.
Old Aug 4, 2004 | 08:59 PM
doodah's Avatar
THANKS, I need to replace u-joint on p-side and possibly a bearing on the d-side! its a 97
edwinsmith
May 18, 2007 06:59 PM
Sean S
17
Mar 21, 2004 11:07 AM
DuallyJeff
20
Feb 21, 2003 05:58 PM
