oil leak
Old Dec 27, 2008 | 08:18 AM
mopar440cu's Avatar
Question oil leak
I have a 24 valve 01 Dodge duallie with a 5.9 Cummins. I noticed last night that I have a oil leak coming from the drives side. It seems to be coming from , what seems to be, under the intake manifold. Does the cummins motors intake come off, and would this leak?? Any suggestion of what it could be? I will take a pic and try submitting it as soon as I can today.
Old Dec 27, 2008 | 08:33 AM
98whitelightnin's Avatar
Its not coming from the over flow bottle on the front of the motor is it?
Old Dec 27, 2008 | 09:34 AM
lovinCTD59's Avatar
Do you mean from under the intake manifold?
Old Dec 27, 2008 | 09:35 AM
scottsjeeprolet's Avatar
Sounds like the Vacuum pump is leaking, very common on our trucks.
here is a link to the fix.
http://www.fixinrams.com/
Old Dec 27, 2008 | 09:50 AM
mopar440cu's Avatar
Yes the intake manifold.
No it nt coming from the over flow.
Where is the vacuum pump located.
I can see it leak oil under the manifold area.
Again I appreciate any info!!
Old Dec 27, 2008 | 09:56 AM
The power steering pump in hooked to the back of it.
Right below #12 in front of the power steering pump.
Old Dec 27, 2008 | 10:55 AM
mopar440cu's Avatar
I checked the pump and its not from there. It is leaking from behind the ecm( on the picture provided its #15) and just to the right of it behind some shield. It looks like a heat shield.
Old Dec 28, 2008 | 08:30 AM
kthiemann's Avatar
Unless I'm mistaken there is a side cover in the area you referenced but I haven't seen many of them leak. Best bet is to steam clean the engine to pinpoint it exactly, if it is the side cover it goes the full length of the motor and is a royal pain to change.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
