Flickering HID....how to fix
Old Dec 13, 2008 | 09:32 AM
WhozNxtLS1's Avatar
Anyways, the more I read the more I see that a lot of 3rd gen dodge ram guys get this problem. I have also read much more that I see a lot of guys wiring in a resistor or capacitor to fix this issue. The wiring in isn't the issue I'm pretty handy, but I just need to know where lol. I'm lost when it comes to finding out exactly where to wire this stuff in. I have an HID kit that has the high/low option, and also came with relays.
Old Dec 13, 2008 | 12:19 PM
WhozNxtLS1's Avatar
From what I read is that you need a 3-4 ohm 100 watt resistor to wire into the low beam side on the factory harness before the headlight plug (male/female end). Anyways, I just was wondering if anyone could help me with A) Where the hell I find a resistor like that? and B) Where exactly I wire this resistor into??
I'm lost
Old Dec 13, 2008 | 01:46 PM
annabelle's Avatar
Try Radio Shack.
Old Dec 13, 2008 | 02:02 PM
WhozNxtLS1's Avatar
Yeah the highest they have is 1.5 ohm and 20 watt. Won't work Thanks for the reply though
Old Dec 13, 2008 | 05:59 PM
04DEEZELRAM's Avatar
got mine from radio shack 20 watt 8ohms and you have to wire it from the low beam wire at your headlight socket to a good ground, that took care of my problems with the flickering.
Old Dec 13, 2008 | 06:17 PM
WhozNxtLS1's Avatar
Thanks, sounds like a Sunday job for me. I'll try that out. How do I know which is the low beam wire??
Old Dec 14, 2008 | 12:21 PM
WhozNxtLS1's Avatar
Question for you guys. Did you guys just splice into the factory harness. Make a cut in the low beam wire and tie into the wire that way? Also did you solder this resistor into the wire.
Old Dec 14, 2008 | 01:07 PM
Yes i used a t-tap to hook it to the low beam wire, and i solder the the resistor to the wire and used heat shrink around the solder, and then ran the other end to a good ground.
Old Dec 15, 2008 | 02:06 PM
WhozNxtLS1's Avatar
I tried installing the 8ohm 20 watt resistor today to no avail. Did not work. Any other ideas?
Strange now though. If I allow the HID's to warm up all the way prior to starting the truck I don't get any flickering?????
I bought the kit with relays so I wouldn't have any problems
Old Dec 15, 2008 | 02:59 PM
Are you getting a lamp out signal??
Old Dec 15, 2008 | 04:37 PM
WhozNxtLS1's Avatar
No I never get the lamp out indicator. I only get the flickering HID on the driver side.
Old Dec 15, 2008 | 04:52 PM
huh and the resistors didnt help??
Old Dec 15, 2008 | 06:12 PM
WhozNxtLS1's Avatar
Not that I saw, I'm pretty sure I did it correctly too =/. I tested the factory plug in with a voltmeter and got 12v when lowbeam was on, other side has 12v when the highs were on. I soldered into the low beam wire, and grounded it out like you said. Didn't do anything. Any way you could get pictures or help me out??? Thanks for all you've done thus far
Old Dec 15, 2008 | 07:10 PM
Hopefully i can get pictures tomorrow for you... wait are you using the stock headlight socket to power the hids or are you using a relay??
Old Dec 15, 2008 | 07:40 PM
WhozNxtLS1's Avatar
I have the stock harness harness with relays yes. I spliced into the stock harness to try with the resistor.
