Flickering HID....how to fix
Old Dec 15, 2008 | 07:47 PM
04DEEZELRAM's Avatar
So are you still using the relays with the socket??...thats whats differant with mine, i dont have any realys on mine just the socket to the hid wiring to the ballast, before i put the resistors in the lights wouldnt even come on.
Old Dec 16, 2008 | 12:39 AM
dodge em's Avatar
04dee, i thought you got yo HIDS from xenongate.com? There site says no error which would mean no flicker nor cap needed? No? (was gonna order from them)
Old Dec 16, 2008 | 12:50 AM
WhozNxtLS1's Avatar
i just want mine to work
Old Dec 16, 2008 | 06:39 AM
Ya i ordered mine from xenongate and them make a nice kit, but since dodge uses that stupid "Lamp Out" thing, i had to use resistors to make it go away.
Old Dec 16, 2008 | 06:41 AM
Ok have you tried to un hook the relays and just hook the Hids up normal with the resistors in place, thats how mine are, im not using relays on mine.
Old Dec 16, 2008 | 11:42 AM
metalli445's Avatar
04, How many resistors did you use?
Old Dec 16, 2008 | 01:44 PM
I used a 8 ohm 20 watt resistor ran from both my low beam headlight wire to a ground, it fools the computer so you wount get a lamp out signal!
Old Dec 16, 2008 | 01:51 PM
metalli445's Avatar
So you only needed one resistor?
Old Dec 16, 2008 | 07:02 PM
One for each side
Old Dec 16, 2008 | 08:35 PM
WhozNxtLS1's Avatar
I will try this tomorrow (disconnecting relays) rained all day today
Old Dec 17, 2008 | 12:00 AM
dodge em's Avatar
yeah im gonna try it again, i gave up and wired it to a relay to my parking lights. I hate hitting another switch to turn them off when i want just parking. Works though
Old Dec 17, 2008 | 02:30 AM
WhozNxtLS1's Avatar
Wait what is that you had to do? lol
Old Dec 17, 2008 | 12:34 PM
WhozNxtLS1's Avatar
Well I disconnected the driver side relay and tried to get the lights to come on without the relay, and the driver side would not come on at all. I the tried to wire the resistor in and still would not come on. I cannot figure this out for the life of me. Getting a little frustrated here. The fog light HID's work fine everytime.
Old Dec 17, 2008 | 08:35 PM
Ill try to get some pics for you tomorrow, thats usually helps me!
Old Dec 17, 2008 | 08:56 PM
WhozNxtLS1's Avatar
Thanks a bunch man. A member here recommended a wiring harness adapter that I can buy, but that is $85.00. =/
