odd codes,truck not running right
Old Feb 23, 2010 | 08:07 AM
danimal 95's Avatar
i already posted this in the engine tech section with no response so i thought i would try here
getting these codes
p0633,p0602 and p0107
they all came on in in a matter of 1 week,and i cant clear 2 of them with my diablo.i alredy used the search but there really wasnt any definative info.it starts and runs fine but under acceleration it will buck once at about 2k rpm then it seems to lose power,if i roll on the gas slowly it accelerates fine???i have already looked at the wiring for the MAP sensor code and it is clean with out ant corrosion,i also removed the edge programmar to eliminate any issues with that,i guess i should put the stock file from the diablo in it as well.any thought would be appreciated
__________________
Old Feb 23, 2010 | 10:07 PM
BigIron70's Avatar
Cummins Guru
P0633-SKIM SECRET KEY NOT ENTERED
reflash the ECM and re-enter code for skim,
if that doesn't fix it replace ECM
Old Feb 24, 2010 | 09:01 AM
danimal 95's Avatar
just curious what would cause these issues after 136k,and no issues at all???the secret key thing is really puzzling because i have never had the ecu flashed or switched keys
Old Feb 24, 2010 | 03:41 PM
BigIron70's Avatar
Cummins Guru
maybe your diablo, "i also removed the edge programmar to eliminate any issues with that,i guess i should put the stock file from the diablo in it as well.any thought would be appreciated"
Old Feb 27, 2010 | 06:08 PM
danimal 95's Avatar
well i took both programmer's off and cleared all the codes,drove it for about 15miles noticed it was very low on power,then the check engine light came back on,same codes,map,secrest key,turbo over boost,ect.took it to the dealer they did an update reflash of the ecu,got in it,noticed same lack of powe and about 10 miles later same codes.now before i go and spend money on an ecu do you really think that will solve the issue?or should i keep looking for other problems first?any opinion would be appreciated
Bad Ramer Jamer
Dec 3, 2007 09:45 AM
ocsurf16
Mar 5, 2007 11:34 AM
vess33
Sep 19, 2006 08:55 PM
9512vCTD
Aug 10, 2006 04:48 PM
