need help with head studs
Old Feb 28, 2010 | 12:23 PM
bossman5453's Avatar
I'm putting head studs in my 99 Cummins and I need some help. As I'm going along from stud to stud they are each a different height are they all supposed to be the same? Some don't screw down as far as others. So in other words, are they all supposed to screw down to equal the same height?
How do you get to the inside head bolts that are under the roller rocker?
Old Feb 28, 2010 | 01:05 PM
Rpainter's Avatar
you have to pull the rockers off to get the studs installed. And yeah if you did not bottom tap the block the studs are going to stick out different lengths. Also remember the 6 longer ones go to the exhaust side of the head
Old Feb 28, 2010 | 01:19 PM
thanks
Old Feb 28, 2010 | 01:31 PM
The six longer ones that go on the exhaust side is that outside of the valve cover on top of where the exhaust manifold is? or on inside?
Old Feb 28, 2010 | 03:27 PM
Rpainter's Avatar
outside closest to the manifold.
12valvetom
Nov 27, 2009 11:37 PM
dieselboy59
Jan 30, 2009 03:57 PM
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
