nv 5600
Old Jan 8, 2007 | 09:19 PM
mogiley's Avatar
nv 5600
Truck is a piece of Edit nv 5600 sheared mainshaft off last month also broke the case when this happened 15000 km out of warranty, dealer the Edit dodge is double piece of Edit no help no transmissions if you do have warranty,anybody else had nv5600 problems
Old Jan 8, 2007 | 09:22 PM
PaulDaisy's Avatar
Wow, man, slow down! Your frustration is well understood! Have a gin and tonic and recall all the good service the truck has given you, obviously you've had it for a while. Failures will happen to all trucks. Let's just be constructive and think how to deal with it. Once you're ready to take action, post!
-P
Old Jan 8, 2007 | 09:35 PM
mogiley's Avatar
nv5600
Your wright i lost it with damiler Edit chrysler phoned head office all you get to talk to is a female who knows nothing about mechanical problems ,is only there to settle you down, not her fault only trying to make a living.Damiler does not care they got your money and will get more.
Old Jan 8, 2007 | 11:22 PM
dodgezilla04's Avatar
sorry about your bad luck. however, when you joined DTR, you agreed not to use profanity, crude, inexplicit, foul, whatever you want to call it langauge. if you go back and read your earlier posts, you will see edit in red.
Old Jan 10, 2007 | 12:35 PM
gmctd's Avatar
Exactly what was happening when that 3"dia 87lb mainshaft sheared off, breaking the case of that 400lb transmission?
Inquiring minds need to know..........
txs
Jan 4, 2004 09:18 AM
prairieguy
Aug 21, 2003 10:07 AM
moparman2
Aug 2, 2003 11:15 AM
MonroeDiesel
Feb 20, 2003 05:56 AM
Superduty12v
22
Oct 11, 2002 07:42 PM
