nuber 5 injector leak???
I bought a set of used 370 injectors for my truck and all but one of them went in and do not leak, and the first time it was spraying abit. I have done some searching and many people say it is probably the copper ring not sealing correctly. So I pulled it out again, there was some "gunk" on the bottom of it so I put it back in, tightened it back down, pulled it out again and it was clean. So I put everything back together took it out again, it didn't spray but it was bubbling right at the bottom. Anyone have this happen to them or hear of this happening?
i need to get new crush washers myself..i have minor bubbling from injector 4,5,6 ...im getting it tommorow from cummins in the buffalo area...anyone know the part number to save me time describing it to them?...my biggest concern is restarting the truck on my own
no grit as in between the bottom of the injector hole and the injector itself..that way the crush washer doesnt sit on crud and won't seal properly regardless of whether its new or old..im gonna stick a vacuum hose in there first and then spray some brake clenaer into the bores and all should be well
I use a shotgun bore cleaning kit the swab gets everything out thats in the injector hole. You can order a injector install kit it will come with new crush washers, put a buger of grease on the injector to hold the washer while putting injector back in.
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
