not starting
Old Sep 21, 2004 | 10:39 AM
BIG&BAD's Avatar
make sure that your fuel cut off solenoid is working or you will be priming forever
for some reason mine didnt work right after i changed my fuel filter
i had to turn the key to on the lift up the lever till it clicked then it finally started
and its been work great since
but i have a backup relay in my glovebox now
Old Sep 21, 2004 | 04:13 PM
jlboren's Avatar
tryed it agaion today primed system till all the bubbles stop coming out but then it sucks back down inside the bleeder have 11 gallons in the tank primed the filter have on of the injector lines cracked still no startnot even feul at teh injectorsshutoff working properly
Old Sep 21, 2004 | 04:24 PM
Smokee's Avatar
You have an air leak somewhere, I think. Use a 12v compressor and a rag to pressurize the tank. You may hear the air leak.
Make sure that the fuel solenoid is pulling up, as suggested.
Old Sep 21, 2004 | 04:32 PM
jlboren's Avatar
how much psi can i use to do it with don't have a 12volt compessor but have a 33 gal with a regulator can turn down line pressure
Old Sep 21, 2004 | 04:50 PM
infidel's Avatar
Don't exceed 10 psi or you may rupture the fuel tank. It will be hard to exceed even 5 psi with just a rag wrapped around a blow gun.
Old Sep 21, 2004 | 06:20 PM
Sidewinder's Avatar
I had a similar problem before and couldn't seem to bleed out the air. So I cracked open an injection line as recommended above and kept the "gas" peddle to the floor while cranking. It did start but ran really rough for about 20 seconds then all was good. I don't know if thats what you are supposed to do but it worked for me.
Old Sep 21, 2004 | 07:52 PM
infidel's Avatar
Sidewinder's method has worked for me numerous times when fuel systems haven't been bled completely. Just make sure you have good batteries then crank the snot out of it, pedal to the floor with half the injectors cracked open. Tighten the injectors and try again with the pedal down. It should start but run rough for a few seconds.
Old Sep 21, 2004 | 08:57 PM
jlboren's Avatar
im starting to think i have a bad lift pump
Old Sep 23, 2004 | 04:09 PM
jlboren's Avatar
i am about to blow the truck up still no start a full week later i have checked for leaks none prime the crap out of it checked the fuel line to the in jection pump no air straight fuel have cracked injector lines nothing pressurized the tank did nothing tried wd-40 not start didn't even try to checked the shut off solenoid working properly i can't get the injection pump to bleed out at all not even a drop at teh injectorsdon't know what to do next startin to pull out my hair help me anymore ideas bad injection pump maybe?
Old Sep 23, 2004 | 05:52 PM
cmckinney's Avatar
Brother had his 2001 truck run out of fuel. A diesel tech that was at the Love's Truck stop put a rag with gas on it on the filter and it started up. Since nothing is working for ya worth a try. Hope you get her running.
-CM
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
FORDNOMORE
Oct 31, 2003 04:02 PM
admin
16
Aug 17, 2003 10:07 AM
