No start leaving me stranded
Old Jul 19, 2009 | 08:19 AM
timmytoo's Avatar
I just bought my 05 3500, 11kmiles, now I am wondering if it was traded in because of this problem of course it only happens, once in awhile, but has left me stranded several times for variuos periods of time.
I get in go to start it, nothing. All dash lights are fine, batteries are up, ( I even put a juimp on it once), but just like someone put a switch in line to cut the power to starter? Then all of a sudden it fires. I noticed a couple of times, the shifter(auto) park doesn't light up, having to wiggle the shifter to see the park indicator light. Is it maybe when in park it isn't making the contact with the relay to to the starter? Computer??
At any rate I am going to get it in the shop has a warranty, in the mean time we won"t be going on the trip we wanted to do. Any Idee ers would be of great help. I did look on recall stuff, found some interior ligh issues and a steering linkage recall, the linkage breaks and you lose control of the vehicle!
Old Jul 19, 2009 | 03:20 PM
Hodge's Avatar
Sounds like the neutral safety switch? Next time it does it, turn the ignition to start, then move/wiggle the shifter? This would help you to either isolate the problem, or rule out the neutral safety switch.
Old Jul 19, 2009 | 03:42 PM
timmytoo's Avatar
will do,am going to take it into shop in the morning, but I will try to fool with the shifter and see if I can make it not start and hope it starts again, at least i could tell em what it is!
thanks
Old Jul 19, 2009 | 04:16 PM
madhat's Avatar
Administrator/Jarhead
When it does that, try starting it in neutral. It could be the switch, or the gear position sensor. (I think that's it... little fuzzy on that.)
Old Jul 19, 2009 | 04:18 PM
timmytoo's Avatar
I can't seem to move the shifter when, it's not running, maybe I am missing sumpin!!!?
Old Jul 19, 2009 | 04:54 PM
timmytoo's Avatar
Okay had to push on the brake, then I could move it to Park DUH! DOPH!
So next time is it happens before i get to dealer, will try the neutral thing.
Old Jul 19, 2009 | 05:11 PM
madhat's Avatar
Yeah... gotta press the break.
Don't worry about it. Stay sane, we'll make it work.
Old Jul 19, 2009 | 08:05 PM
timmytoo's Avatar
I will keep ya'll informed as to what happens. I did check my Steering linkage I am lucky it's not on recall, one small step!!!
Old Jul 22, 2009 | 12:08 AM
timmytoo's Avatar
The problem with the no start wiggle the shifter, turned out to be a relay switch inline from Park possition, so replace of relay and me truck she runs again!
I love this truck!
Brad5502
21
Nov 13, 2011 10:48 PM
jrobe
Mar 27, 2011 09:23 AM
20
Nov 20, 2002 08:13 PM
Hoss
Oct 25, 2002 11:52 AM
