No start, after pump work
Old Jan 23, 2005 | 07:44 PM
QUICKMCSS's Avatar
1997 12v 5 speed.
all stock we moved the plate full forward rotated the star wheel a few turns twards the motor, and put in a boost elbow....
During the test drive about 2 min in we went WOT and the truck pulled awesome then lost all power and died on the side of the road, would not restart and was pouring fuel out the tail pipe.,
Help?
.....when the truck was put back to stock it still would not fire. truck needed for work in the AM, any help would be great...
Cell phone 847-812-2894
-charlie
Old Jan 23, 2005 | 10:36 PM
Hemi Cat's Avatar
Sounds like the lift pump failed or the overflow valve failed. The lift pump has one way check valves that will pop apart and loose all fuel pressure and flow in less than a second, then the truck dies like you shut it off. If the exh pours out white smoke while cranking, it will probably be the pump timing slipped.
Old Jan 24, 2005 | 09:31 AM
infidel's Avatar
The new found power caused your timing to slip
Old Jan 24, 2005 | 06:20 PM
QUICKMCSS's Avatar
Ding ding ding.....
Got a hold of piers and several other places this AM and it was a collective thought that the timming skipped.
Got it set back to what we thought was ok.... it started. bumbled a lil bit in the upper RPMs and we tried to set it a few more times, with no results on starting. The owner is working on the truck right now setting the timing another way right now....
Thank god the pump didnt die, the truck was 24 hours old when we turned it up
thanks for your help guys
Josh Robbins
Jul 11, 2014 12:18 AM
CoolumConst
Oct 11, 2008 10:00 PM
cLAYH
Sep 3, 2006 10:56 PM
Black Days
Aug 9, 2006 03:09 PM
