No start after filter change!!!
Old May 27, 2010 | 04:15 PM
JimonaWing's Avatar
I just changed the fuel filter and now the truck will not start.
I ran the lift pump through several cycles to prime the engine. The filter canister is full...I am getting fuel.
Any suggestions?
Old May 27, 2010 | 04:45 PM
billmac's Avatar
I just went through the same thing. After cycling the LP several times my truck still wouldn't start so I depressed the accelerator pedal to the floor, turned the key and kepted cranking until it started which was within 45 seconds. Do not run the starter for more than 60 seconds when you do this. It will overheat. If it still won't start, wait a few minutes then try it again. My truck has never failed to start using this method, which I might add, is out of the Chrysler service manual.
Old May 27, 2010 | 05:10 PM
rebal's Avatar
you might have to open a injector line at the head to bleed the air out
Old May 27, 2010 | 06:37 PM
JimonaWing's Avatar
Thanks guys...I opened up an injector line.
Running good now!!!
440FURY
Jun 11, 2006 08:12 PM
steverctx
21
Nov 18, 2005 07:45 PM
Ian
Oct 5, 2005 05:40 PM
jlells01
Sep 1, 2004 08:42 PM
sjester
Aug 1, 2004 07:50 PM
