No Start
No Start-NEVER MIND
Truck ran fine with Mini Max for several years. Don't think that is an issue. When to start and got some kind od noise but no crank. Not a click like solinoid but no crank.
Lights, radio, everything comes on (including Mini Max) but no crank. Mini Max fault codes P2509 and P2299. P-2509-ECM/PCM Power Input Signal Intermittent. P-2299-Brake Pedal Position/Accelerator Pedal Position Incompatible. Both refer to throttle/brake pedal intermitant or incompatible position. Anybody know if this is the throttle position sensor or what?
Any help would be appriciated as the truck is dead in the garage right now.................
BKTC
BKTC
Did you check the battery voltage? One quick check you can try; now that the truck is in the garage, turn the headlights on so that they shine on the wall. Then try to start it and watch what the lights do. Do they stay the same brightness, or dim considerably?
Let us know what you find.
Well after chasing all the fault codes and researching the associated parts/sensors I find out it's bad batteries. A friend had a similar problem with the "lightning bolt symbol" and his turned out to be bad batteries as well. Did a load check on batteries and both were bad. New batteries and all is well again.
Mexstan........had I seen you response sooner I might have saved myself alot of research.........Thanks
TR
TR
