No power-black smoke
Old Nov 11, 2007 | 09:33 PM
zeek's Avatar
Truck 2002, 6 speed, stock, starts fine and give it fuel, starts to fall on its face and lots of black smoke .4 codesp-0460, p-1693, p-0216, p-ecu.. Help now. stranded.. Thanks
Old Nov 11, 2007 | 10:08 PM
phox_mulder's Avatar
P-0216 is a bad one, usually means the injection pump is on it's way out.
P-0460 points to the fuel level sender in the tank.
Neither of those usually leave black smoke as a symptom though.
Black smoke either too much fuel or not enough air.
Check the air filter, then look for loose or totally blown off turbo boots, then look at the turbo itself.
phox
Old Nov 11, 2007 | 10:52 PM
skynyrd's Avatar
does it sounds like the turbo is spooling and can you hear a boost leak? have someone keep their head under the hood as you rev it and listen for a boost leak. do you have a boost gauge on the truck?
Old Nov 11, 2007 | 10:54 PM
blackdiesel's Avatar
Registered
injection pump is toast, replace it
Old Nov 12, 2007 | 10:28 AM
zeek's Avatar
Thanks for the replies, I kinda figured on the pump or at least the lift pump. Bummer...... It does spool up and no gauges, and don't here any air leaks through all that noise. Eddie
Old Nov 12, 2007 | 10:33 AM
belgianmagic's Avatar
try having someone listen up front while power braking ...the SMOKE means no air more than pump...you are getting fuel...JUST NO AIR
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
