No Power
No Power
Today i finished putting a new gasket on the timing gear cover. had to take the whole front end apart, radiator,intercooler,condenser,bumper ect. well got it all back together. Truck started thank god, but when i took it out for a drive it made a loud whining noise and i had no boost what so ever
HELP
sam
HELP
sam
You might have forgotten to tighten a clamp down for the elbows, or one is leaking due to improper fitment or is has split. Double check all your connections you had apart!
Beat me to it!^^
Beat me to it!^^
the boots are good. now what, could it be the timing slipping, i did notice that the hard lines going to the condensier and then going back are bent bad. Could this be it also they are bent preety bad.
This is definitely a boost issue. High EGTs are the number one tip off. I have made up adapters to hook up the inter cooler to a shop vac with the blower feature, I cap one end and pressurize the system, then i listen with a stethoscope for a the leak. Also, by murphys law, the inter cooler boots will always crack where you cant see them, be sure to use a mirror to look completely around them and squeeze them with your hand to expose the possible crack.
Cheers,
Harold
Cheers,
Harold
Cheers,
Harold
Cheers,
Harold
powerwagon440
Jan 20, 2003 08:50 PM
pwabbott
14
Dec 20, 2002 08:23 PM
