no over drive, tach, speedo and fuel solenoid not working
Old Jun 19, 2006 | 05:34 PM
dgage's Avatar
I was driving the truck last Friday and stopped off for a coffee. I came out and the truck would start and then quit right away. I had it towed home and researched the problem on this site. After I read about the fuel shutoff solenoid, I could keep the truck running by holding the lever up by hand. So I disconnected the sloenoid and could start and stop the engine by manualy mover the fuel pump lever. I can use the truck now but now I don't have any tach, speedo, overdrive and the wait to start light dosn't work anymore. Are these things interconnected somehow? I don't want to spent the $500.00 on a new solenoid only to find out it was something else causing it not to work.
Thanks for all your help
Doug
94 Dodge Ram - Stock- 5.9, 12 valves
Old Jun 19, 2006 | 06:52 PM
infidel's Avatar
All the things you mention plus the water in fuel sensor share the same 5 volt output from the PCM.
My bet is that one of the five volt wires is shorting to ground or that you have a bad ground.
Old Jun 19, 2006 | 10:20 PM
dgage's Avatar
Okay, i'll check it out tomorrow. Thanks!
Sleigher
May 4, 2017 02:12 PM
fox1972
Jul 14, 2010 05:27 PM
Need95-00CTD
40
Sep 17, 2008 01:11 PM
jmon12
Jan 29, 2007 07:50 PM
bigfoot
Aug 14, 2004 02:22 PM
