No headlights
Old Sep 17, 2005 | 12:21 AM
longhorn's Avatar
No headlights
Hi a couple of days ago when I was pulling my 5th wheel flatdeck I noticed my trailer lights werent working.
I tryed my signal lights and only the ones on the drivers side of trailer were working with no tailights or brake lights.
Thinking it was trailer wiring problems I unhooked the trailer .
Then my cab marker lights and tailights on truck quit working.
It was getting dark but I made it home without tailights.
Thinking I must have fuse problems I started checking the fuses ...............but now my headlights dont work!
Ive had light troubles before but usually the headlights always keep working?
Truck is a 1991 3500
Thanks
Old Sep 17, 2005 | 05:50 AM
handymantim's Avatar
If the fuses are OK then I'd look at replacing that multifunction switch (turn signal, high beam, etc.)
Old Sep 17, 2005 | 08:52 PM
bmoeller's Avatar
I suspect a ground problem and/or a bad headlight switch.
Old Sep 18, 2005 | 09:30 PM
longhorn's Avatar
I finally got time to take out switch.
It looks meleted around one connection so tomorrow Ill buy a new one and try that.
Where should I look for checking grounds?
Thanks for the help.
Old Sep 18, 2005 | 09:40 PM
Desperado's Avatar
Repalcing the switch should take care of most of your problems, my dads 91 did the same thing, replaced it with a switch for a 1995, now they work great.
Old Sep 21, 2005 | 10:27 PM
longhorn's Avatar
Ok I put in a new switch and it started to get hot and blew a couple of fuses.
After looking at it close it looks to me like the plug that goes to the switch is burnt?
So I went and cut the whole plug out of another older Dodge pickup and will cut mine out and splice in this other one if the wiring looks the same?
Theres 10 wires coming out of it , whats the chances they are going to be the same between a 1987 and a 1991?
Old Sep 21, 2005 | 11:22 PM
torquefan's Avatar
That's pretty common. You need to replace the headlight switch and connector. Both are available now in the aftermarket. Then you need to rewire the system so the trailer's tail/marker lights draw power through a relay, because your headlight switch can't handle that much current.
Old Sep 21, 2005 | 11:52 PM
longhorn's Avatar
Where would you put the relay?
Would I need a relay on every wire going to the trailer?
Thanks for the info.
Old Sep 22, 2005 | 12:59 AM
infidel's Avatar
Just the wire that powers the trailer's running lights (ones that are on all the time when the lights are on) will need a relay.
My understanding is that most switch meltdowns are caused by running the dash lights way dim, switch gets hot. This can be compounded with added on bulbs on the dimmer circuit such as gauge lamps.
I guess some people have overcome this by drilling a 1/4" hole in the vent duct close to the switch to provide air flow over it.
Old Sep 25, 2005 | 04:31 PM
longhorn's Avatar
So I got another light switch plug out of a older Dodge pickup.
I cut mine out and went to attach the new one and found out Ive got 2 more wires in mine?
Guess im going to have to try and find a aftermarket one?
Old Sep 26, 2005 | 09:49 AM
infidel's Avatar
Don't know anout a '91 but for '94-'97 Napa has the switch for $31
Old Sep 26, 2005 | 10:34 AM
longhorn's Avatar
Thats for the switch right?
Where am I going to find a plug?
I phoned 2 parts places and they never heard of just the plugs?
Extreme Diesel
40
Dec 25, 2006 11:23 PM
Hunter
13
Dec 20, 2002 05:59 AM
kingofdodge7131
Dec 14, 2002 02:43 AM
24
Dec 2, 2002 08:19 AM
