Better Headlights needed.
Old Nov 19, 2002 | 08:01 AM
latitud_rt's Avatar
Re:Better Headlights needed.
Sylvania makes a set of replacement lights that are rated at 4000K of power. This is just below hid but much brighter that stock or &quot;blue&quot;. They can be found at most any parts store and run about $50 set. They are called SilverStar.<br><br>Tim
Old Nov 19, 2002 | 08:33 AM
rattle_rattle's Avatar
I hear that some people have had problems with melting headlight housings with higher wattage bulbs. I too, would like to put in brighter bulbs but am a little nervous about that. Any input would be appreciated on this one too. Thanks for starting the thread Diesel Phil.
Old Nov 19, 2002 | 10:47 AM
latitud_rt's Avatar
The Sylvania bulbs are not higher wattage, just a different lighting technique. check www.sylvania.com for more info.<br><br>Tim
Old Nov 19, 2002 | 11:23 PM
Extreme Diesel's Avatar
https://www.dieseltruckresource.com/...art=0#lastPost
Old Nov 25, 2002 | 12:39 PM
CWICKHAM's Avatar
I'VE READ ALOT ABOUT SPORT HEADLIGHT CONVERSION ON TDR. WAS WONDERING IF ANYONE ON HERE KNEW ABOUT IT.
Old Nov 25, 2002 | 04:43 PM
DuaneWKKC's Avatar
Maybe LukeS can help us here, The 9004CB (cool blue) look like the same wattage as factory (65w/45w), but the 9004ST (Sliver Star) look like a higher wattage (70w/50w). I do know that there is some issues about light switch's burning up with bigger bulbs. What can our stock non-sport switch's handle?
Duane.
Old Nov 25, 2002 | 07:46 PM
Srigs's Avatar
I installed a set of Cool Blues ($9 a piece) and boy is the color much whiter, better night vision, won't blind people and will now not buy any normal type of bulbs ever again.
Old Nov 26, 2002 | 12:04 PM
latitud_rt's Avatar
I installed the SilverStars this past weekend. They are 70W high, 50W low. Much cleaner, not as yellow, light. I have never heard of the headlight switch &quot;burning up&quot; by using slightly higher wattage beams. Aren't the headlights controlled by a relay? I will post pictures as soon as I can. You can definetly tell a difference, now if I can only fix those weak back-up lights.<br>
Old Nov 26, 2002 | 12:37 PM
DPG's Avatar
DPG
J.C. Whitney has halogen backup bulbs that replace the OEM stuff, I think I am going to give them a try. I'm not real happy with my backup lights, but I don't really want to add aftermarket lights. I'll let you know.
Old Nov 26, 2002 | 02:21 PM
CWICKHAM's Avatar
is anyone a member of turbo diesel register?,,tdr online?,,,<br>there are quite a few members saying that the dodge sport pickups have a different pattern and use higher wattage bulbs.<br><br>they are taking these assemblies and installing them on their<br>slt's...for what its worth
Old Nov 26, 2002 | 02:46 PM
yz's Avatar
yz
Well why were at the subject of head lights. How do you adjust them if you can? Both of my head lights are aimed to the right and it is starting to drive me crazy. I went through the owners manual and it only shows how to change them. And I don't have a service manual. Thanks for the help. -Anthony
Old Nov 26, 2002 | 04:55 PM
yz's Avatar
yz
anyone???
