No Boost!! help needed
Old Sep 22, 2005 | 11:24 PM
desertboy's Avatar
ok guys i realize this is my first post here but i need help, The truck is a 95 2wd dually 3500. On this truck the lower end was rebuilt about 10k ago. Has ats manifold, 4k gsk, AFE intake, ground fuel plate.
Well i installed 215 injectors moved the fuel plate forward a bit, the star wheel was already as far forward as it would go. I now have no boost, hooked up 35 psi to the turbo inlet and had no leaks so i'm stuck any ideas???
Would an overflow valve or lift pump cause this? i'm at a loss thinking maybe something in the AFC housing gone bad/ not installed correctly?
Please help.
Thank you
Old Sep 22, 2005 | 11:31 PM
high country's Avatar
check the turbo to verify it moves freely, then look at your boots on the intercooler
Old Sep 22, 2005 | 11:38 PM
desertboy's Avatar
Turbo spins freely and all intercooler boots didn't leak a bit when i pressurized the system to 35psi
Old Sep 23, 2005 | 12:42 AM
P.O.R.'s Avatar
is the waste gate working freely.
Common
May 23, 2008 05:05 PM
rockittboy
Jan 22, 2007 01:09 AM
Little-bit
Apr 24, 2006 07:22 PM
csramsey640
Aug 28, 2005 08:38 PM
TE-44
Dec 15, 2003 10:06 PM
