New South Bend Clutch
My stock clutch gave out at 179,000 miles. My good friend own a tranny shop and installed the new clutch for me today. Now I am facing a new issue. Before the new clutch I would have trouble shifting once in a while. It acted like it was grinding gears. Now with the SB Con O clutch you have to push the clutch all the way to the floor to shift or it will not shift into gear. My tranny guy says it has to be the hydraulic system. Current hydraulic system has fluid in it with no leaks. He says the hydraulic system is non adjustable. Any thought on this or suggestions......?? Thanks......
update
Replaced Hydraulics. Still hard shifting. And I can not get it into 1st or reverse... I still have to have the clutch pedal completely against the floor just to shift without grinding.. ***????
When I replaced mine, I had problems at first when shifting. I figured out that I wasn't depressing the clutch far enough. My fix was sliding my seat a tad forward. Hope it works out for you.
When replacing my tranny, I managed to break the ball-stud that the fork pivots on. I was having the same symptoms as you and it was caused by the fork pivoting on the bellhousing, rather than the ball stud. I bled the clutch a milliion times, but never saw the fork was out of whack because the rubber boot was in the way. Double check all the clutch fork geometry.
bleedable
System bleeds it self. Hydraulics come from Dodge as a sealed unit. Been there, done that....
Truck now shifts, but has hard shift. I can shift 1 through overdrive. But in order to get into reverse I have put it in overdrive then into reverse.
Cluth pedal feels good. Even if I push clutch pedal all the way to the floor I still have hard shifting.......
randallp84
Jun 1, 2010 05:15 PM
