Brand New South Bend Clutch Won't Release
Old May 29, 2010 | 07:24 PM
randallp84's Avatar
Ok, need some help here. I bought a South Bend OFE and installed it this weekend and I can't get it to release with the clutch pedal. I took the slave cylinder out and pushed the fork with an apparatus that I fabricated out of pipe and all-thread then turned the driveshaft manually while the transmission was in gear so I know that it WILL release. The stock clutch worked fine. Any ideas?
Old May 29, 2010 | 07:52 PM
Raspy's Avatar
Not enough information.
If there is air in the system it will not release. Did it work for a while and then quit? Does the pedal feel "normal" or easier than normal?
Old May 29, 2010 | 08:18 PM
randallp84's Avatar
The new clutch did not work at all, as soon as it was installed. The pedal feel is about the same as the stock clutch was, but is and always has been stiffer than my dad's 03 with the NV5600. I did not open the hydraulic system at all other than checking the fluid, so I don't think there could be any air in there, right?
Old May 30, 2010 | 08:47 AM
randallp84's Avatar
Bump...
Old May 31, 2010 | 01:17 AM
gadget.35-06's Avatar
Did you replace the stock master/slave set? South Bend says the stocker won't last with their clutches.
Old May 31, 2010 | 09:58 AM
randallp84's Avatar
No, I did not replace the stock hydraulic system.
Old May 31, 2010 | 10:16 AM
1985cucv's Avatar
yes ive read you need to replace the hydraulics as well because the stocker isnt sufficient.
Old May 31, 2010 | 11:46 AM
NickBeek's Avatar
SB and Valair both recommend upgrading the hydraulics with their new clutches. I replaced my hydraulics when I installed my Ofe and have had no issues with it.
Old May 31, 2010 | 03:44 PM
randallp84's Avatar
The hydraulics could be the problem because it was extremely hard to get into reverse the last couple of days before I installed the south bend.
Old May 31, 2010 | 10:27 PM
hitcb1789's Avatar
dont want to hijack the post but i just bought a used truck with a southbend and how can you tell if the hydraulics are aftermarket?
Old Jun 1, 2010 | 11:22 AM
CaptainKelley's Avatar
hitcb,
Look at the reservoir first. If it sits on the master cylinder, it's stock or oem. If it's remote, mine is screwed to the firewall, probably upgraded.
Old Jun 1, 2010 | 05:15 PM
randallp84's Avatar
Figured it out. I, being the genius I am, did not tighten the pressure plate bolts down all the way.
chuck'64
Aug 19, 2010 09:23 PM
dalefans2
21
Mar 5, 2008 12:19 PM
biglar
Nov 20, 2006 10:08 PM
West Coast
Dec 16, 2005 10:15 AM
