new at this/need help quick!
Old Nov 24, 2005 | 05:18 PM
rustynuts's Avatar
i have a 97 12v with no mods. has excessive blow-by. blowing out about 1.5 gal. of oil per 100 mi. pulling stock trailer on recent trip to colorado. on return trip i overfilled and did not have to add oil in 700 mi. whats up with this? can vaccum pump pressurize crank case and cause this problem? power is good and truck runs ok. is there a fix or will i have to rebuild engine? thanks; rustynuts.
Old Nov 24, 2005 | 05:31 PM
turbox2's Avatar
How many miles on the engine? Rusty
Old Nov 25, 2005 | 05:32 PM
rebal's Avatar
are you sure its not your vacuume pump pukin oil out??
Old Nov 26, 2005 | 10:01 AM
durasmack's Avatar
Also check front case.... could be KDP and where it is going to as you drive could make it look like it is from somewhere else.... Vacuum pump is a good place to check too..... Good luck.
-Trey
And welcome to the site...
Old Nov 26, 2005 | 12:49 PM
John Faughn's Avatar
Do a compression test , then theres a tool that I've seen on the tool trucks for checking plowby but never bought one.
Old Nov 26, 2005 | 04:20 PM
firestorm's Avatar
Also, check your exhaust pipe and the post turbo boot for signs of oil.
Old Nov 26, 2005 | 05:39 PM
infidel's Avatar
If oil is coming out the blowby there are usually only two potential problems, vacuum leak or engine needs rebuilding.
roxxx
Nov 28, 2008 04:47 PM
donhov
32
Apr 21, 2007 10:19 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
jet
Dec 6, 2002 09:11 AM
Haney
Nov 25, 2002 11:26 AM
