new fuel pump truck doesnt run
Old Nov 4, 2007 | 11:20 AM
cmed250f's Avatar
hey guys im having some problems right now....i installed a new fuel pump in my truck and now it doesent run....i filled the fuel filter housing with fuel cracked the injectors and bumped the truck so many times and can only get drips of fuel out of the first one i am stuck here and have no idea what to check next any information would be greatly appreciated thank you
Old Nov 4, 2007 | 11:45 AM
rustyshakelford's Avatar
are you sure the new fuel pump is working properly? whats the psi into the vp44? could any contaminants have gotten into the line?
brett
Old Nov 6, 2007 | 12:28 AM
glenn-k's Avatar
Going yet?
Pull the banjo at the VP from the filter, and bump it a few times - should get solid fuel even before starting during the short lift pump cycle- and it should run all the air from the lines.- pull the plug exiting the filter also if you want until all air is out of it, and have most of the injector lines cracked at the head - min - the 4 or 5 easy ones. Tighten them as fuel shows up while cranking.
Geebeer
Dec 17, 2008 03:54 PM
wildchild97
21
Nov 4, 2007 06:31 AM
powerstrokin03
May 6, 2007 11:19 AM
Timmay2
15
May 17, 2005 05:09 PM
600 Megawatts
16
Jan 31, 2005 09:14 PM
