new 2004 update
Old Nov 2, 2003 | 11:22 AM
vet10te's Avatar
new 2004 update
(update one of the replies said maybe someone had put gas in tank, went out checked my receipt and shows to my horror i put 22 gals of regular in, there was alittle more than 1/4 tank
am i screwd.what do i do now,,,,,,,,,,,help :'(
Old Nov 2, 2003 | 11:29 AM
Mikey4X4's Avatar
Re:new 2004 update
DON'T take it to dealer. Drop and drain your tank and pull fuel filter. Fill back up with diesel and purge lines till getting diesel to filter. Install filter and go about you bussiness and dont tell anyone YOU DID THAT!
Old Nov 2, 2003 | 11:30 AM
DODGE4X4's Avatar
Re:new 2004 update
Get all the fuel out of your tank. Drain the fuel lines. Drain the fuel/water filter out completely and replace filter. Fill it up full of Diesel and Pray. You might want to wait for one of these other guys to post on here to b/c they know more than me but, I would start getting all the Gas out you can.. How far have you gone with gas in it????
Old Nov 2, 2003 | 12:34 PM
Smokee's Avatar
Re:new 2004 update
vet10te
Glad that I could help. Clean things up, dump in additive. Don't tell dealer.
Everything should be fine if you didn't drive too far. Even then, don't panick.
george
Old Nov 2, 2003 | 12:40 PM
RCW's Avatar
RCW
Re:new 2004 update
You will not have hurt a thing. Just follow everyone's advice and get the fuel out of your tank and install new filters in a week or so. You do not even need to get it all out, just down as far as you can. Refill with fresh diesel and drive it enough to be able to add another quarter tank in a day or so. Keep the mixed fuel for your lawnmower. If it is 3/4 gas it will work just fine there or in a car without a cat converter!
Old Nov 2, 2003 | 01:33 PM
amartinson's Avatar
Re:new 2004 update
Just as the other guys said, don't be too worried about it. Get as much of the fuel out of the tank as you can, drain the fuel filter canister and replace the filter. Fill the canister and the tank and get it re-started. It will be okay. This happens all the time at my work and as long as you don't try to drive it for a long period of time with unleaded in it, it will be fine. What you really don't want to do is put diesel in a gas engine. One of the drivers at work put diesel in a V10 Dodge PU and melted all the pistons.
Old Nov 2, 2003 | 10:33 PM
DODGE4X4's Avatar
Re:new 2004 update
Well did you get it running good agin ??? ??? ??? ???
Old Nov 7, 2003 | 08:36 PM
vet10te's Avatar
Re:new 2004 update
thanks for all of your help,i also have a 99 f350 ford power stroke never did anything that dumb,
my wife and sons will not let me forget it
dodge seems to be ok remove all the fuel about 25 gals and refilled put 1000 more miles and no trouble,it just shifts strange and i smell fuel at times.
again thanks for all of your help.
i have been told if i had done that to the fordand drove 60 miles would have had major damage.so far i like the dodge better than the ford,everything works out will trade ford in spring for another dodge. ;D
floridagc
18
May 30, 2006 07:57 PM
MnTom
Aug 25, 2004 11:19 PM
bmallen
Feb 29, 2004 10:30 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
