need transfer case
Old Apr 15, 2003 | 09:56 PM
Rome's Avatar
need transfer case
My transfer case is leaking all the fluid out from where the driveshaft exits it. The dealer says I need a rebuild. They are going to give me 15% discount but I am still looking at a $1500 bill. Just checking to see if there are any out there.<br>Oh, unfortunatly it was run dry for a few months down in Baja. Any suggestions would be helpful. Thanks.
Old Apr 16, 2003 | 02:38 PM
Superduty12v's Avatar
Muted User
Re:need transfer case
Buy a NP205 off E-bay and stick it on. Cheap, Strong, and simple.
Old Apr 17, 2003 | 07:33 PM
Redleg's Avatar
[quote author=Rome link=board=13;threadid=13648;start=0#128479 date=1050461760]<br>My transfer case is leaking all the fluid out from where the driveshaft exits it. The dealer says I need a rebuild. They are going to give me 15% discount but I am still looking at a $1500 bill. Just checking to see if there are any out there.<br>Oh, unfortunatly it was run dry for a few months down in Baja. Any suggestions would be helpful. Thanks.<br>[/quote]<br>I'd get a second opinion. Does it function ok? I went to a mechanic that works on a lot of 4x4's and heavy trucks. Regular rate $55 an hour. Cost just a little more than $250 to put new seals in, plus I needed shims for the front output shaft. He didn't charge much for that. Whe I went in asking to have it rebuilt, he was pretty confident it wouldn't before he even looked at it.
Old Apr 19, 2003 | 11:15 AM
Stamey's Avatar
As others have said, I'd go for the seal replacement. The first thing I'd do though, is fill up the transfer case and run it in 4wd to see if there is damage to the gearing/internals due to lack of lube. If it works OK, then do the seals. If not, look for a replacement case. You may be able to buy one cheaper.<br>You'll need to clearly identify your transfer case<br>MT, std duty 241 transfer case, 23 tooth<br>MT, std duty 241 transfer case, 29 tooth<br>AT, std duty transfer<br>MT, HD 241 transfer case (has PTO gear), 23 tooth<br>MT, HD 241 transfer case (has PTO gear), 29 tooth<br>AT, HD transfer (has PTO gear)<br><br>But look here: http://www.car-part.com<br>I have seem them for less than 1,000.00 there. For that you can buy it AND put new seals in before installing.<br>Another possibility:<br>http://www.truckpartsunlimited.com/<br><br>Chris
Old Apr 21, 2003 | 10:48 PM
Haulin_in_Dixie's Avatar
Of course I cannot speak for the condition of the rest of the transfer case but the leak at the rear is easy to fix. It has a sleeve bushing just like an automatic transmission does. Pickup the seal and the sleeve and take the extension housing off the case (in the truck) If you cannot change the bushing take the tail housing to a transmission shop and they can change it in a few minutes. In actual practice you must drive out the old one and drive in the new one, usually a large socket will make it as a driver. Use a larger socket and with it reversed, drive it in until it bottoms out. Pop in a new seal and it is like new. That part of it is an inexpensive repair, probably $25 bucks or so.
wyododge
Aug 18, 2011 07:48 AM
blacksmoker
Oct 9, 2006 12:55 AM
jojosdad
Sep 9, 2006 02:05 PM
MR HYDROSEED
Jun 8, 2006 07:42 PM
