need help with oil pressure
I don't know much about deisels I have a 01 3/4 ton 104000 miles on it. Run fine it seems but when I come to a complete stops .Oil preesure gauge drops down to 0 and the check gauge light comes on . Any clues on whats wrong and how to fix.
might be oil pressure sender or the oil pump, its not good if its that , i would not run it until you find out. There are plugs on the driverside of the engine to hook up an oil pressure gauge to check it manually.
From: Dayton, NJ (temporarily while In USCG on Staten Island)
Install a mechanical at the L/O filter housing in the blank plug next to the turbo supply line. This will give an accurate measure of actual oil pressure. The plug on my 01 is 1/8", I ran a -4 aeroquip to a mechanical gauge in the cab, that way I know exactly what I am running.
You need an oil psi switch. $287.00 at the dealer. Cheaper ones can be found online.
oil pressure sending unit Cummins part # 4921511. $66 CDN right from cummins, retail for $87. Any cummins dealer can get them.
Also, Blue Streak PN PS407 is supposed to be the same thing, but I am not willing to order one to find out, so cummins it is.
5 minute install, pressure gauge is back to normal.
GlennRMK
May 24, 2007 10:46 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
QWKRTNU
Oct 24, 2006 08:23 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
