NEED HELP FAST!!!! Clutch
Ok here is my problem i have no clutch. i push the petal and nothing the petal just moves freely. what happened was hauling hay and went to push the clutch in to down shitf and nothing it stalled had to start it in gear and drove it till i got the feild looked for leaks around master cylinder nothing. So i should just replace the master cylinder or could it be the slave cylinder. it will build a little pressure after a while and hold for about 2 seconds i need my truck asap so any help is appreicated
Best to just change both.They are sold preassembled from the dealer for around $150 give or take a few dollars.You can get them individualy from NAPA but it is a guessing game and it is a pain to bleed the system.If you want to spend a few extra $$$(Approx. $300) get the heavyduty upgrade set up from Southbend.
I replaced my clutch for my 97 last dec with 13 inch upgraded MU13-1,25 Con O and replaced it with the SBC Heavy Duty Hydraulic assembly Hyd-X-1.25 master hydraulic assembly all filled with fluid and ready to install. Its for 1998-02.
Cost $300 now. I got it at Source Automotive here but you can get it direct from SBC:
http://www.sourceautomotive.biz/inde...emart&Itemid=1
Look here on SBC site and scroll to bottom of page:
http://www.southbendclutch.com/dodge.html
Easy to install
Dave
Easy to install
Dave
well got all the parts from Napa an read how to bleed it and everything but still no pressure cant get it bled right anyone have any tricks we pumped the slave till no more air bubbles and it is really tight but the master cant get it tight
EdmontonCanada
37
Dec 9, 2009 03:18 AM
wwm
Feb 26, 2009 08:37 PM
jmccart
22
Apr 20, 2007 03:02 PM
