Need Help Bad!!!
Old Apr 2, 2007 | 09:22 AM
Mo. Dirtracer's Avatar
Need Help Bad!!!
My son has my truck in SC.Just called and said truck ran fine this morning but now it's running real ruff and blowing white smoke.He also said it won't pull away from it's shadow.Truck had new lift pump and ip put on it in Dec.
Any ideas???
Old Apr 2, 2007 | 09:26 AM
DIESELRYAN3500's Avatar
Tell Him To Turn The Key On,off,on,off Then On Again And Give Me The Codes Reading Off The Odomiter
Old Apr 2, 2007 | 09:33 AM
He did and all it has is the 1693 code (companion code) Could it be some bad fuel?Fuel filter was also changed in Dec. Is there anyone up around Rock Hill South Carolina that could help him out?
Old Apr 2, 2007 | 09:43 AM
When The Lift Pump Was Replaced Did You Go With The Intank Pump ?if So Your Connection On Top Of The Fuel Tank Could Have Come Loose Or He's Getting Alot Of Air In The Line Somehow.usually When This Happens It Ends Up Being The Ip Is Out, Even Though Yours Is New
Old Apr 2, 2007 | 09:48 AM
I went with the stock type lp. Is there anything he can visually check.The truck will start up and rev but after that I can't really say what it does.He just says it sounds rough.
Old Apr 2, 2007 | 09:52 AM
START BY BUMPING THE KEY WITH THE DOOR OPENED. HE SHOULD HEAR THE LP RUN FOR TWENTY SECONDS. IF HE CANT HEAR IT WITH HIS HEAD BY THE FUEL FILTER THEN THE LP WENT SOUTH AND PROBLY TOOK THE IP WITH IT
Old Apr 2, 2007 | 09:58 AM
Boy, this is beginning to make me sick.His Cummins is in the shop here in Mo. having a computer put in it that went out going to SC. Thanks for the help...Frank
Old Apr 2, 2007 | 10:29 AM
Dr. Evil's Avatar
Hate to tell you this - BUT, running rough and blowing lot of white smoke are very often signs that the IP is shot.
key on/off trick rearely works (I dont know why so many people think it works)....to extract the other code(s) you need to have the truck scanned with an OBDII code reader.
Its absolutely critical to have a fuel pressure guage in the cab.
Good luck.
boosted7
May 4, 2010 10:09 AM
65fury
25
Apr 6, 2007 08:16 AM
Czapla44
May 7, 2006 02:03 PM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
