need some help bad real bad
Old May 5, 2006 | 06:23 PM
Czapla44's Avatar
anyone have any ideas on the easiest way to put a turbo on a 03 dodge turbo being a 12/62 high tech turbo if there are any ideas on the easiest way to put one on if you guys could let me know
Old May 5, 2006 | 06:28 PM
dodgetech77's Avatar
I like to remove the r/f wheel and remove the inner fender liner.
Old May 5, 2006 | 06:33 PM
Czapla44's Avatar
would that be the easy way to do it but the only catch is that the waste gate is in the way and with motor mount its all messed up just want to hear some opinions on it and one other thing i have diesel in my motor oil what causes that
Old May 5, 2006 | 07:08 PM
texaspower19's Avatar
you dropped a injector probaly
Old May 5, 2006 | 08:56 PM
Czapla44's Avatar
I understand that I dropped an injector but how do i get the turbo in the truck
Old May 5, 2006 | 09:07 PM
srry i thought u asked wat cuases disel in ur oil
TEXASPOWER19
Old May 5, 2006 | 09:09 PM
Czapla44's Avatar
TEXASPOWER19
I did but I also need to know some easy ways to get the turbo put in
Old May 5, 2006 | 09:12 PM
masonic-dodge's Avatar
Take all the bolts out of the exhaust manifold execpt for the one that has the nut on the stud which I think is the 3rd from the back and raise the front of the manifold up as far as it will go. By doing this it will give you enough room to slide the turbo in over the motor mount. You will also find that the oil return line needs to be installed befor the turbo is put in. You will need to take the 2 studs closest to the motor out of the manifold and cut 1/2" off of them to clear the top of the turbo. Before you start you will need to get a short 15mm wrench to get to the front inboard nut.
I hope this helps. A 2nd set of hands will alot because that turbo is very heavy.
CRIS
Old May 5, 2006 | 09:31 PM
Czapla44's Avatar
CRIS
so you saying that i need to cut the studs on the manifold that are closest to the motor correct
Old May 5, 2006 | 09:43 PM
Yes you need to cut just the 2 studs. I fount this out when I went to install mine on my 05. It took me 3 times of putting it on and off to figure all this out. I'm glad that my problems are going to help someone. If you can, get someone to help you with the job. All of this can be done from the top with the fender liner on the truck. You will also need to cut the little pin off of your factory exhaust elbow before you mount it to the turbo. That pin is used at the factory for lining up the elbow with the turbo but there is no hole in your new turbo for that pin.
CRIS
Old May 7, 2006 | 02:03 PM
Czapla44's Avatar
CRIS
Thanks so much for the info that worked perfect took exhaust manifold off and trimed the bolts sucked it down tight stuck it right in the truck perfectly thanks for the advice
snowman
Jun 28, 2004 05:14 PM
dieselman24
Mar 28, 2004 02:59 PM
Rocket95
Jan 13, 2004 10:45 PM
doomgaze
Feb 6, 2003 06:51 PM
